Glossy LCDs Confusion
altjx
I've purchased an ASUS 24" Glossy Black monitor from Newegg about a year ago, and then I've just purchased another one, but 23" which also stated it was Glossy Black. The issue I've realized I've run into is that I interpreted "Glossy" as in the actual screen being glossy. Personally, I prefer to have a monitor that has that nice gloss to the LCD, but it appears that the only thing glossy about these ASUS monitors are the black frame around it, which I don't care for.
I do not know too much about monitors and the exact feature I'm looking for. Is there something I should be looking for while I look for monitors with the glossy LCD? Apparently, searching for Glossy LCDs on sites like TigerDirect, Newegg, Bestbuy, etc, doesn't appear to yield me the results I'm looking for. (because the ASUS monitor that I currently have shows up in the results, when it doesn't have a glossy LCD)
When I refer to Glossy LCDs, I mean the kind of monitors you can look at and it almost appears to be a mirror because it shows the reflections of everything. Can someone help me identify the monitor feature I'm looking for?
I've noticed that a lot of the monitors listed as "Glossy Black" refer to the frame in almost all cases. What you want is a "Glossy screen" or "Glossy Display". I personally can't stand glossy screens, so when I was recently shopping for a new monitor I ran into the same problem you are experiencing. Most of the manufacturers I was considering didn't even list glossy/matte on their own product pages! Infuriating!
I guess the only way to figure it out for sure is to either read tons of reviews (Newegg reviews usually mention it somewhere if you read enough) or see the product in person. Calling the store or manufacturer is probably an exercise in futility, as most drones won't be willing, or able to help. On Newegg you can also search filter the reviews for keywords, so maybe typing "glossy" or "matte" into a search of the reviews might help. Good luck!
http://en.wikipedia.org/wiki/Glossy_display
Oh ok. Glad I'm not crazy then. Thanks man!
