glossing cases
Matt Samoohi
I have a coolermaster tsunami blue edition thaT I purschased off the forum. I think it has a good amount of gloss but i was wondering if I vould make it more glossy-er that would be great would pledge work?
The simple way would be to wax it and it'll look clean. The next step up would be adding a clear coat to it. I don't think a rattle can clear would help ......any sort of automotive clear would be fine if you have the tools. You wouldn't need much to clear the case.
I think you could do it with rattle can clear, but it'd be a painful process (been there, done that). Ditto on the automotive clear recommendation, unless you're a glutton for punishment, heh.
