Glass top silverstone case?!
I think that's the mini-itx NAS case they're making or have made. I'll try and look up the model designator.
My google-fu's failing me at the moment and I gotta go to work shortly. It does exist and I did see something written about it somewhere. Might've been a youtube vid even. Good luck!
looks to be about the same size as the 09
i'm wondering if it might not be plexiglass though, since plexi is much lighter than glass... and less probably less prone to breaking during shipment too :p
It's a mini-ITX file server case. 5x 3.5" HDDs, SFX PSU, single low-profile expansion slot. The motherboard sits vertically with the rear I/O facing down.
More pics here.
Wow, looks like there's a ridiculous amount of wasted space inside, given the location of the the drive bay, mobo, and PSU. Also not a fan of the acrylic top, particularly how it's secured.
Definitely agree with you on the top. It looks simply awful.
yeah, the blurry pic looked a lot better than the clear one. probably b/c i could not see those screws in the acrylic and all the other bits and pieces in the blurry one :p
THX for the info guys. It doesn't look as nice as I thought :( I'll pass on this one
