Give me 3dmark 2k1 tip
camay123
Im at 19676 3Dmark 2k1 point and want to break the 20000 milestone. Give me some pointers.
I already have max oc my cpu , my gpu, I have used Rage3d 3dmark 2k1 optimisation.
Any windows XP related trick
Any hard drive optimisation trick
Let me know
speed up timings, something that is often overlooked.
Also, run 3dmark 2001 in realtime mode.
3.456 Ghz OC 2.4C P4
Ati AIW 9700 Pro
Im now at 19811 3DMark.
Getting closer.
Mem timings is already at 2-2-3-6, The best I can do. Below that windows wont boot or it kick me out of 3dmark.
Ill check on those link jwill. Thx
you're within the statistical fuzz of 20k
go run the test, then run the test again. I've found the second run is often about 40-50pts ahead.
Just keep running it, your bound to improve. I can randomly get 20k one test, retest and get 21k... You should be able to get 20k just keep trying.
