Gigaworks S700 vs.....
Justinkoko
I just salvaged Sony home theater system from my garage...and I thought..
Currently owns:
Creative Gigaworks S700 with X-Fi XtremeMusic
Planning to get:
Front: Insignia™ Model: NS-B2111 Bookshelf Speakers
Center: Sony Home Theater grade speaker 5 years old
Rear: Sony Home Theater grade speakers 5 years old
Sub-woofer: Anything that's modern $100-150 suggestion?
Receiver: Sony STR-SE391 5 years old..
" * Audio-video (AV) receiver: STR-SE391
* Stereo mode power output: 100 watts x 2 (40 to 20,000 Hz, both channels driven into 8 ohms, THD 0.5 percent)
* Surround mode power output: 80 watts x 5 (all channels driven into 8 ohms at 1000 Hz, 0.8 percent THD)
* Analog audio inputs: 3 (including 5.1-channel inputs)
* Analog audio outputs: 1 (stereo RCA), subwoofer out
* AV inputs: 2
* AV outputs: 2
* Surround effects: Dolby Pro Logic decoding, other digital signal processing sound fields including Virtual Dolby Surround
* Remote control: Yes
* Rear-channel stereo: Yes
* AC outlets: 1
* Headphone jack: Yes (1/4-inch phono)
* Speaker selector: A, B, A+B
* Tuner preset channels: 30 FM/AM
* Auto-tuning: Yes
* Direct tuning: Yes
* Receiver dimensions: 17 by 5.5 by 11.5 inches "
Planning on connecting this receiver to my X-Fi via analong wires..
Will this setup outperform my current Gigaworks setup? Is the difference worth doing it? (I can save about $100 by selling my Gigaworks..)
Link for the whole Sony home theater system
Mostly because I'm trying to recycle my stuff..
I just happened to find Sony Home Theater set today and I wondered how it would fare if I invested in better front speakers..
So it'd sound better right?
For sure, you'll get much better sound out of that system, especially if you pick up some towers for front spearkers. You'll get a much more compelete sound than a sub/sat computer system.
Or you could just use your current Gigas and hook up the Insignias up front. I think that would be a better solution and a CHEAPER one at that.
That's what I would do.
