So I got caught speeding, tried OC to 4.6 before making 100% sure everything under that was working. But I am back on the right track now, with the Gigabyte boards/bios I just am not sure which method I should persue. Here is what I have been able to get a stable OC at:
Bios version F5
4.4 core speed with turbos
PLL CPU Overvoltage = Auto
RAM is rated 9-9-9-24 1T 1600 which is how I have it set
using manual Voltage (1.275) and LLC level 6 (level 5 wasn't stable, level 6 raised voltage by 0.012 and I guess that worked) I am getting 10 passes on intel burn using max memory, temps are 62 degrees and 66 degrees on core 3 (which is always higher), idle jumps from 29-32. Voltage in idle goes from 1.272 to 1.284. Voltage under load mainly goes from 1.296 to 1.308 but sometimes jumps to 1.332.
Now the other option is:
using "normal" voltage and the dynamic rating of +0.125 I also run stable, the idle temps and load temps are the SAME, but voltage is a little different. Under load its the same normal 1.296 to 1.308 but maxes at 1.344 (although this is rarely seen). BUT at idle it goes from 0.996 to 1.044 with the occasional jump to 1.116.
So it seems like they both run the same voltage and temps under load and are both stable, but one will volt down a ton more (using Dynamic which doesn't allow you to use LLC at the same time). The question is, which is better for the CPU? to have the volts be a ton lower when not pushing the CPU or to have a more stable voltage all the time?
Also when trying for over 4.4 should I use one method over the other for stability? I am not sure if I will go higher though because when I was toying with 4.6 I had load voltage around 1.35 and it was still not stable! might just have a bad chip and can't go that high, or I will need to go 1.40 volts which is not worth it to me for the small increase in performance over 4.4
Bios version F5
