Gigabyte X79-UD3 spacing
Hardass
I want to add waterblocks to a second vid card. I need to know the pcie slot spacing on this mobo to get correct connector for them. It is full and running and I do not want to shut down to measure. Can anyone help.
Thanks.
Then you need the one for 40.6mm spacing.
The space between two expansion slots on a board is always 20.3mm.
The x79-ud3 has one slot in between the two 16x slots (i.e they are two slots appart) for some reason koolance calls this one slot spacing, sorry to cause confusion.
Hope this helps
Hope this helps
If your right it helps.:D Thanks.
