Loafdogg420
- Jun 2, 2010
Hi all,
Sorry in advance for the wall of questions.
So, I just put the mobo in my sig under water. The mosfets and the ICH, IOH. I picked up the EK acetal + nickel blocks a couple of weeks ago from perf pc's. My problem is this, the temps on my board are significantly higher than they were, specifically the TMPIN0 and TMPIN2. First thing I did was try to identify which sensor corresponds to what. I found mixed answers on both the gigabyte forums and various others. Pretty sure that tmpin1 is a general system temp, what im not sure of is the other two (one has gotta be the NB right?). That's my first issue.
After seeing the increase I immediately thought it was the result of mis-mounted blocks so I reseated both the mosfet and ich/ioh. The result was the same. My TMPIN2 is reading ~60C at the lowest! With the stock heatsink I was seeing temps 20C lower.
Everybody else is happy, the cpu and gpu are both chillin as normal.. And, although gigabyte says thats a perfectly acceptable temp, im thinking to myself.. why did I spend money on these blocks to have higher temps!??
Is it possible that a component on the board which was transferring heat to the stock heatsink is no longer being cooled due to the installation of these blocks?
Any liquid users out there, with this mobo, having similar issues?
Much appreciated!
Much appreciated!
