Unless you're watercooling, I would suggest it over the Extreme model. I got the Extreme model and now wished I would've gotten this one. The extra NB heatsink on the Extreme basically prevents you from using the two top most PCI slots - and it's hard to know if the heatsink really works any better.
Other than that, the board is pretty awesome. Has been very easy to OC my 920 to 3.6-3.8GHz with very little effort and stable to boot.
Save yourself the $50 and get this board instead of the Extreme!!!
Just installed it - no OC done yet, a need 4 more days till my OCZ goldies arrive, then we see "how FA can it go" Tho reapers keeping steady on 1.525 1333mhz (might try to go bit forward with them tomorrow)
Raid set up with no problem, everything works as intended. Oh... Gigabyte, you could add something that Asus is using to connect all the chassis connectors without a problem
CPU area is kinda clear - put there Noctua with dual fans, and it fits perfectly. They also added those nice SATA cables which are protected from being pulled accidentally out. There is no other clearnce problems - the Xfi titanium fits the upper PCIex1 slot, just along the gf280
The only problem I see might be with 12 gb of ram - the noctua fan is blocking one of the white slots, however with 6 or 3gb it won't be used, so no problem there so far.
During windows operations (copying, installing) the CPU runs at 25C and system on 40
