Gigabyte X58-UD5 Overclocking Help
You can get to the stock speeds? Idk why you cant play COD my friends old am2 with a 4670 ICEQ can play it just fine. Reset the BIOS to factory spec and try again. im not sure what else i can tell you on the matter, good luck.
I'm looking for tips in improving my overclock and not running the system and stock settings.
