Does this board offer whatever it's called that cuts the CPU Mhz in half at idle? I can't find it anywhere, and my CPU is at it's full speed even when idling. On my Asus board with an AMD CPU the CPU Mhzs are cut in half when at idle.
I have the regular UD5, so I'm assuming that the Extreme does too...
if you are referring to CPU throttling (not sure what the correct terminology), then yes it should do that as my CPU is speed is cut in half when not gaming / benching
but maybe you should check your Asus Bios features?
