I have numerous of these mobos still in use... on one I'm getting a problem with RAM (or mobo?)
The windows and motherboard report the incorrect amount.
6gb installed (4 usable) in windows info/properties.
I re-seated/cleaned and it went to 6gb usable most of the time, still 4gb sometimes.
I then installed the same exact ram to make it 12gb total, and it now consistently shows 4gb available of the 12.
(MSConfig has no MAX set -- even in BIOS it shows 4GB)
Not too sure what else to check?
