Stereodude
- Oct 20, 2000
So I finally got my two 2x4GB 1600MHz DDR3 G.Skill Sniper kits yesterday from Newegg. I installed them and noticed something peculiar with my P67A-UD3P. If I leave them at 1333MHz (XMP Profile disabled) the system will dynamically change the CPU multiplier as the load on the CPU changes (as expected). If I enable the XMP Profile or manually set them to 1600MHz (the only change made in the BIOS) the system will no longer dynamically change the CPU multipler, but it instead just sits at max speed.
I've been using RealTemp 3.67 to monitor things.
Has anyone else seen this?
