Gigabyte P35, socket A mobo,socket 939 3700+, Cradlepoint CTR350
shamgar
I have accumulated more things to sell, here we go:
My Ebay Feedback
My Heatware Feedback
I would have more Heatware, however many people do not leave Heatware feedback.
I do not think that I am interested in any trades at the moment, however you can let me know your offer.
I accept non-cc PayPal as payment.
PM me for extra pictures or if you have any questions. I can have them uploaded to a server quickly for you.
Shipped prices are to anywhere in the continental US. Contact me for shipping costs if you're located anywhere else.
Feel free to make offers on anything, but please no lowballs.
NOTE: With any purchase I will give you a FREE DVI cable. They are brand new, straight from DELL. Connect your monitor using a new DVI cable instead of that old VGA cable and get better picture and be able to use more resolutions on your lcd/monitor!
gigabyte GA-P35-DQ6 retail motherboard
This was an RMA from gigabyte. This is a brand new board. I have not used it.
It is still under warantee. It has a 3 year warantee.
Included is:
2 port firewire bracket
i/o bracket
one sata bracket and power connector and esata cable
cd
manual
2x sata cords
Ide and floppy cable
http://www.pcstats.com/articleview.cfm?articleID=2118
pcstats review
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2637
Intel® P35 + ICH9R Chipset
Supports Intel® Core™ 2 multi-core and 45nm processors
Supports DDR2 1066* memory for outstanding system performance.
Ultimate graphics performance with dual PCI-E x16 interface
Integrated SATA 3Gb/s with RAID function
Features high speed Gigabit Ethernet and IEEE1394
Ultra Durable 2 motherboard features High Quality CPU Power design with Ferrite
core chokes, Low RDS (on) MOSFET and Solid Capacitors.
Durable Capacitors that take advantage of Japanese manufactured SMD (Surface
Mount Device) solid capacitors for enhanced system durability.
All New Copper SILENT-PIPE that includes heat sinks covering MOSFET modules, the
north bridge and the south bridge.
Audio controller from ALC 889A codec and DTS Connect, featuring 106 dB Signal to
Noise ratio and support for Blu-ray.
gigabyte homepage overview of board
$90 shipped, board was $300+ when it came out. If anything you could melt down
all of the copper on this board and sell it and make money!
SOLD
KinetiZ 7T SOCKET A motherboard retail with 2 IO shields
also comes with an ISA ethernet card,
RTL8019AS
also i will include an amd 1ghz athlon chip.
UPDATE: ALSO i will include 4 sticks of 64mb ram or 3 sticks of pc133 for an extra $5
UPDATE2: I will also include an agp graphics card, your pick of a voodoo3 or a rage128 ultra.
also if you really want i think i have a spare old 10gb hard drive lying around. basically you will have a complete computer! i prob have an old 300w PSU if you need as well - but that would raise shipping charges
http://www.qdigrp.com/qdisite/eng/Products/K7T.htm
ITEM
DETAIL
Chipset
north bridge:VIA KT-133
South bridge:VIA VT82C686A
Bus Type 5 PCI slots
1 AMR
1 AGP
1 ISA
CPU Support Socket A AMD Athlon and Duron Processors
AMD Athlon Processors at 750/800/850/900/950MHz ,1GHz, 1.1GHz
AMD Duron Processors at 600/650/700/800/900MHz 1.0/1.1GHz
System Memory Three 168 pin 3.3V PC133 DIMM sockets
Supports up to 1.5G SDRAM
Supports 66/100/133 MHz Synchronous DRAM and VCM SDRAM
And 66MHz EDO DRAM
Power Management ACPI V1.0 and APM compliant
Supports S0, S1, S3, S4, S5 ACPI power status
Auto adjust FAN speed in the different power status
USB 4 USB ports (2 for I/O panel and 2 for front panel)
USB 1.1 specification compliant
Bus Speed 200MHz FSB
Overclock up to 266MHz FSB maximally
BIOS 2 Mbit Flash ROM
Licensed advanced AWARD BIOS
Supports Plug and Play
Supports ACPI and OS directed power management
Storage system Two PCI Master IDE ports support up to 4 IDE devices
Supports ATA66
One floppy port support up to two 3.5¡± or 5.25¡± floppy
drives(360K/720K/1.2M/1.44M/2.88M)
Supports LS-120 floppy disk drive and ZIP drive
I/O Feature 2 High Speed Serial Ports (16550 Fast UART Compatible)
1 Enhanced Parallel Port Support EPP/ECP/SPP
1 PS/2 keyboard port
1 PS/2 mouse port
IrDA port support up to 115.2Kb/s transfer rate
All I/O ports can be enabled/disabled by BIOS setup
Graphics AGP 4X Support
Universal AGP Slot
Transfer rate up to 1 GB/s
Onboard Audio Software Sound (Option 1)
AC¡¯97 2.1 Compliant
16-bit Stereo Codec
Hardware Sound (Option 2)
Creative 5880 PCI Sound Chip
Advanced Feature Wake up on LAN
Wake up on Modem
Trend ChipAwayVirus on Guard
PC-cillin with killing function
Override processor ratio by jumpers (PCB2.0 support overclock function)
QDI Innovative Technology RecoveryEasy, BIOS-ProtectEasy, ManageEasy, LogoEasy
System Health Monitoring CPU temperature, System temperature, CPU fan speed
Chassis fan speed, 5 System Voltages
Board Size ATX: 305X244mm
Question: What is the fastest CPU can be used on the Kinetiz series mother
boards?
Answer: Because of the limit of the chipset Appollo KT133 chipset, the K7B/T can
only support 100Mhz FSB based processors stably. The K7B/T supports Duron up to
1300Mhz and 100Mhz FSB based Athlon(ThunderBird) up to 1400Mhz(14x100Mhz).
However, the K7E is based on Appollo KT133A chipset which can support 133Mhz FSB
absolutely. So The K7E can support all of the Duron, Athlon(ThunderBird) and
AthlonXP Palomino and ThoroughBred processors. The fastest processors is Athlon
XP 2600+. If you choose a processor faster than AthlonXP 2000+, the motherboard
with the lastest bios maybe cant detect it correctly. In this case, please login
our online furom and contact to Qditech, the moderator of the furon, he will send
you a beta bios to support these processors.
Link: NONE
time: 2002-10-29 9:35:44
latest bios 01/08/2004: K7B_V41lcp.zip installed
$40 shipped
Kingwin ABT-700MA1S power supply
JK i decided to use it! sorry!
Cradlepoint CTR350 router with flashed firmware to latest version
http://www.cradlepoint.com/ctr350/ctr350.php
The CTR-350 creates a Secure WiFi Hotspot from broadband-enabled cellular phones
and modems. Enjoy the simplicity and convenience of WiFi without having to search
around for a hotspot and without risking a non-secure connection.
A WiFi extension to Cellular Broadband
Compliant with IEEE 802.11 b/g Standards
Tethers to Cellular phone or Cellular USB modem for WiFi access anywhere in
coverage
Compact and portable
Charges handset via USB or powers USB modem
10/100 Ethernet port switchable for WAN or LAN
Added firewall prevents unauthorized use of your cellular connection
basically i had this thing and it is AMAZING!! you can plug in your cell phone
with data or a mobile data card, and then you have a wireless hotspot to anyone
you want!!!! also if you want you can just hook an ethernet wire up to it and use
it as wan or as lan. this thing is amazing. you can just plug in an internet
cord off your router and use this as a wirless router as well! and it gets great
reception also!!
i also already flashed the latest bios on the ctr-350 version 2.2.1
so you dont have to worry!
bought it for around $140
I am selling it for $80 shipped
AMD Athlon 2400+ Thorton
AXDC2400DKV3C 2402505C40200
AQYHA 0409WPMW
with heatsink + fan
$25 shipped, $20 shipped for just the CPU
Athlon XP 3200+ socket A Barton
selling for $50 shipped (comes with an all copper heatsink and fan)
SOLD!!!!!!!!
5. HIS X1950 PRO IceQ 3 Turbo 256MB AGP
This card is amazing. Comes stock overclocked and is a dual slot cooling design so it pushes all of the hot air out of your case. I will recommend that you have a fan on the outside of your case blowing cool air into your case to keep this card extra cool. Make sure that you do not have a vacuum sucking all of the air out of your case from other fans or this fan on the graphics card will not work at its optimal capacity. This fan really does keep the graphics card and memory cool and you can overclock this card even more than it already comes overclocked as well!
HIS X1950 PRO IceQ 3 Turbo 256MB AGP Product Link
One thing I will mention is that when I first installed this card getting the drivers to work was somewhat difficult. It would "Blue Screen of death" upon bootup. What I did was I
1)Downloaded the latest drivers
2)booted up into safe mode
3)tried installing the drivers in safe mode.
4) If that didn’t work then I would go to the hardware manager tab under system, and right click the agp video card, and then I chose update driver
5)I chose have disk and browsed to the folder where the latest ATI drivers were put.
6)I installed those drivers and then everything was perfect.
It took me a while to get this done but when people say these cards don’t work well, perhaps they are not trying those steps.
My personal suggestion for this card: Download ATI tool 0.27 beta 4, set the fan to constantly work at 100%. Also for extra stability you could underclock the core back to around 580 from 590 but you do not have to. You can overclock the memory as well on this card. This card can play everything from stalker, age of Conan, the Witcher, wow, etc at really great framerates.
I am selling this for $75 shipped. comes with dvi to vga adapter, s-video output cable, and molex to pci-e power connector.
i also now have a socket 939 3700+ (2.2ghz) single core processor for $35 shipped.
thank you, i thought i was being pretty fair as well.
bump and lowered the price on the power supply and the cradlepoint router
also if you are interested in anything shoot me a PM and make an offer.
argh bump seriously just make some offers i want to get rid of this stuff, be reasonable but dont be afraid to send an offer
by the way the x1950pro comes with a dvi to vga adapter and also an adaptor for a molex plug to a pci-e power plug
I'm pretty interested in the x1950 and Barton 3200 but can't find the CPU in the post cos I'm too tired! Can I get the card to the UK if I pay for International 1st class post?
well i had thought i sold the barton 3200+ but i waited and held it for someone and that didnt pan out so i wasted my time.
so bump and i lowered the price on things and with the socket A motherboard i will be including a 1ghz athlon thunderbird processor now.
