gigabyte P35-DS3R help
SoAndSo
I have a gigabyte p35-ds3r and im trying to figure out how to control my yate loon 120mm exhaust fan and my arctic cooling freezer 7 pro heatsink by using PWM
http://i37.tinypic.com/21jyc9c.jpg
i currently have my arctic cooling freezer 7 pro plugged into the green circled fan header (4 pin plug to 4 pin socket), and the yate plugged in the blue one. The yate is a 3pin connecter and so is the connecter itself. My question is this.
How the heck do i set it up in the bios to use PWM so they fans ramp up and down as needed? im pretty sure i have it set to auto and EIST is enabled. I have googled and i think these are the correct settings to use, but i cant hear any change in either fans RPM.
Thanks
I think that PWM only works for 4 pin fans that are plugged into the 4 pin ports supplied on the mobo. So I assume that your Yate Loon fan is incapable of PWM.
Do you have the option to get a fan controller or some sort?
hmm, i suppose i could look at getting a fan controller. i didnt even think of that tbh.
PC Health Status-> CPU Smart FAN Control: Enabled->CPU Smart FAN Mode: PWM. ;)
Only the SYSFAN_2 can be controlled via SpeedFan, I'm not sure if the BIOS has some speed control on that fan header...
The SYSFAN_1 has no control.
