Hi all. I'm sure some of you encountered this problem with gigabytes mobos when you save your overclock for example and come at a later time to see it back to default settings. Has a permanent solution been found to this problem? I have the latest BIOS of course but that does nothing to remedy the problem.
When I first noticed the problem in my mobo, I had to remove the cmos battery for some time before the mobo can get into normal operation. Now, it just goes back to default and I had to go BIOS setup and load my saved profile. But still, that is annoying as hell.
It is not worth it to change the mobo at this time of course. What do you think I should do? Any comments? Suggestions?
Thanks.
Thanks.
