Dear Sirs,
Im writing you to help me resolve some issues I am having with my motherboard. It is GA-81848P775-G, with Intel P4-650 CPU being 3.4 GHZ # LGA775, which was purchased through SMK Superstore on 12/06/05.
After installing the motherboard and processor, I installed Corsair memory, 1 GByte, twin X matched pair, the # TWINX1024-3200C2Pro, had no problems with boot up after installation of ram and no hardware problems. Once everything was installed, OS and softwares complete, I then went into the bios and noticed that the clock settings were 3-8-3-3, I called the Corsair techs, and was told CAS Latency time 2, the active to precharge delay 6, Dram ras# to chs # delay 3, Dram ras precharge 3 and the volts should be set at 2.75. I then went into bios and set the above settings. Then I re-booted. Once it booted up, I started easy tunes 5 program, went into the advance mode, and set the voltage from 2.9 to 2.8, then re-booted the system. After boot up, I used my flatbed scanner in which crashed the system. Tried it, with several different software programs, at the 2.8 setting and it still kept crashing the system. I then went back into the Easy Tune 5 and re-set the voltage at 2.7, and again tried using scanner and other software programs and it still kept crashing. I then called the techs at Corsair and told them of my problems and they suggested that I use the Memtest 86plus to test each stick alone and then together, no problems. Pasted the test.
Is there any thing that you might tell me as to what settings on the motherboard I need to use to run this ram at tech specs. I know the motherboard is more than capable of handling this ram, I had it tested at SMK Superstore, I dont know what type of ram they used while testing. I must be doing something wrong , I need to get this corrected as soon as possible because if it turns out to be something wrong with the motherboard, I only have a few more days in which to return it for exchange of another.
Would you please respond as soon at possible, thank you in advance for your time and knowledge.
Your friend in need,
Pi2leo
Gigabytes responce was use ctrl + f1 for more opitions in bios .
some help! They could not have read my e-mail at all, to come up with this responce.
could some one help me with the settings in bios needed to run my ram where it should, with out crashing my system?
Pi2leo
