Gigabyte Mobo Help
bunnytrigger
I believe i plugged the front usb ports into the "speaker" and "INFO" pins........
After that my motherboard just stopped working. Hoping that it was just my power supply I checked and it was bad, replaced it, and got the fans and everything on the MOBO to work, except, I get no video output from the agp nor PCI slots......tested the vid cards on my other pc, and they are not the problem.
anybody can guide me in the right direction?? this is the mobo i have:
http://www.gigabyte.com.tw/Products...rd&ProductID=1646&ProductName=GA-8IPE1000 Pro
All helpis appreciated,
Thanks in advance :)
quick question... is the ICH5 chipset supposed to get too hot?? hot enough to burn ur hand if you touch it?? :D I just touched it and IT IS HOT!!
my mobo then?
Did you plug in the 4 pin power connector to your mobo? I exprienced the same symptoms and spent like 10 minutes scratching my head lol. i dont think the chipset is suppose to get that hot when you didnt even get into windows ..
yeah, 4 pin power connector coming from the supply is in place. IT does indeed get very hot, I tried touching the one on my sister's computer and it it warm to the touch but not the the point where it is intolerable to keep your finger on it like on mine....
Honestly, i don't care to if I have to buy a whole new mobo, i just cant find the same one NEW......and i don't know if i can trust refurbs
update: I cant seem to find another one anywhere online. Anybody has one that might want to sell?? OR suggestions on what to replace it with???
