Gigabyte M61PME-S2 update problems
msjones
Hi,
I have a GA-M61PME-S2 motherboard with an Athlon 64 X2 5000+ CPU. I would like to run a bios update but it wont run under vista 64.... any ideas on how I can get this to run?
I am having some problems getting my 4GB to work. They are a matched pair but only 3GB is showing up in Windows..... and the same in OpenSUSE. The max for my board is 8GB and I am running 64bit versions of windows and Linux.
I have tried the ram in another machine and all is fine so im thinking it may need a bios update.
Thanks in advance
Mj
