have a quick question about this board and set up, maybe you guys can help me.
Gigabyte K8NSNXP - 939 Nforce3 Ultra Chipset
pc 3200 ram - 1 gig
amd 64 3500 90n
fx5900ultra 256ddr
When i first got the board, the dual channel wouldnt work, i was ont he phone with tech support they really had no clue they told me it was the ram ...yea ok, mushkin-r rated and garenteed to work with this board....so before i flipped out after spending 200 dollars on this board, i booted up in single channel and loaded xp...flashed the bios to the current which was F6, walll laaa , board now boots in dual channel mode...BUT the ram wont run at its rated speed, i tested it in softseeks memory test... single channel it scored 3100 dual channel it scored 6300....theres the whole reason i wont just(as gigabyte tech said) run it in single channel....the ram will only run at 166mhz (333) stable it boots at 200 but sometimes it makes windows , sometimes it dont, usually crashes to a complete reboot while in windows. its not bad ram i tryed 3 other brands...the bios has a ton of features and settings, im setting the ram exactly to its specs.... i cant seem to find out the problem.. anyone help? i also ran memtest86 ram is ok, and the board is mega stable as logn as you run the ram at 333 - 166mhz
pc 3200 ram - 1 gig
amd 64 3500 90n
fx5900ultra 256ddr
