Gigabyte K8NS Pro owners...
motithejrt
What kind of HSF are you using and did you have to get a seperate backing plate? I am looking for something to replace my stock HSF. Most install guides on manufacturer websites require the removal of the motherboard from the case (NOOO!!) Any luck or recomendations?
P.S. I looked into the thermalright xp-90 which is supposed to be excellent but thermalright specifically states you need a special backplate but no one sells it (Newegg doesn't and I called frozencpu.com)
i have a gigabyte k8n pro, the backplate didnt come with the motherboard itself, but i baught a new hs/f and it came with 1 so im sure when u buy a new hs/f it will be included
