gigabyte HDTV question
tomciob
hey guys
i'm looking for a video card that has vivo capabilities, i am not a gamer.
i think i'm going with this one. (gigabyte, x700pro)
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=322247
my questions is concerning HDTV out on video cards.
this particular one says tv out in the title
but in the description says "DVI-I and TV-Out connector supported, S-Video to HDTV(Ybrbc) Cable bundled"
does that mean its hdtv, i thought DVI was by default HDTV.
thank you
Yes the card has video in option so it is VIVO. Not all HDTV's have an appropriate connector for DVI from a PC. Mine for example has an HDMI input rather than DVI. The S-Video to HDTV(Ybrbc) Cable bundled is to use the component inputs on the TV if you need to use that route.
