Gigabyte HD 6850 OC temps
pokevitek
Hi, please anyone with this same card, what idle temperature you got in idle and how many % of fan speed you have? I have 40 °C in idle with fan on 48%. Temp is fine, but 48
% seems to much for idle state. Thanks.
Ten degreees less? Hmm that sound even impossible. I mean, only bench I found was that this card with 72% fan had 34 degrees. You must have super-cooled case....
I have two 6870's in crossfire both overclocked as in my sig for my second machine. The top one idle's at 31c the bottom one at at 27c. This is in a slightly modified Thermaltake Armor case with pretty good cooling. Room temp is at 20c. Both cards have fan speeds at 75% and ramp up to 100% at 60c. Both cards have had X23 TIM installed and all of the factory TIM scraped off.
They peak at about 68c when gaming and about 80c when running furmark or occt.
When I have just one card in the case it idles around 27c and peaks around 68c with occt running.
