Gigabyte H55M-ISB3 SATA-SSD problem
culthuu
This is a problem I first submitted to the Data Storage section of the forums but now I’m sure the problem I’m experiencing lies with the motherboard. I’m sorry it’s a long post but the problem is complex. My primary system is based on a Gigabyte H55M-USB3 Rev 1 motherboard with an i5 661 processor. This is a P55 chipset motherboard & I’m running Windows 7 Ultimate X64. I use the integrated graphics since all I use this system for is email, web surfing and downloading. It has 4 gigs of Corsair XMS3 1600 memory. When I built the system 6 months ago the storage array consisted of (1) WD Black 750 Gig drive and (1) 1 Terabyte WD Green drive for storage. The Black drive had a Windows partition and an Applications partition. The system was set to AHCI and ran with no problems.
2 months later I bought a Corsair Nova R60 SSD to use as the boot drive. I installed it on the 0SATA port and plugged the Black drive in the 1SATA port and the Green drive in the 2Sata port. Outside of a Blu Ray burner on the last SATA port that was the extent of the storage. The SSD seemed to install fine and worked without problem for 4 months. Then I purchased a WD Silicon Edge 64 Gig SSD and decided to install it as the boot drive in place of the Corsair R60. At the same time I updated the motherboard BIOS from F6 to F8, again without any problems.
I thought the installation went well but then the system started to shut down completely at random times. Starting it back up brought up the ‘load windows normally’ screen but it would always boot up OK. Checking the system logs showed nothing except the system shut down with a ‘kernel power’ problem. The system is using a 750 Watt Thermaltake power supply so I doubt it’s starving for power. I changed SATA and power cables and moved the SSD to different power conns but it made no difference. Strangely enough every time this happened I seemed to lose my log in information on my Internet sites such as Gmail.
My first thought was the new WD SSD was bad but I put it in another of my machines and it worked fine. And the Corsair SSD works in a different system. I put the Corsair SSD back in the Gigabyte system after using HDDErase to wipe the drive but it too shut down the computer. So my next assumption was the bios update had screwed things up. In the intervening few days since I updated the bios, the F9 update was released so I updated to F9 but no resolution to the problem. Then I reverted to the original F6 bios but the problem persists. I’ve tried Gigabyte drivers, Intel drivers and the Microsoft drivers installed when Windows 7 installs but the problem only got worse. Then I discovered something strange. The SSD would only get through installing Windows 7 if the Black drive was connected with the original windows partition. If I tried either SSD alone the install would fail after the first reboot. But if the Black drive was connected then I could install Windows but with the shutdown problem. The windows install on the Black drive does not show up as a boot option and is apparently separate.
I submitted the problem to Gigabyte and their solution was to up the voltage on the memory. I did what they asked simply because I didn’t have a better solution. It didn’t work. Apparently it didn’t sink in that this system works without problem except when I put an SSD in it. I’m beginning to wonder if the chipset SATA controller might be bad and I never realized it since I left the two hard drives attached when I originally installed the SSD.
Right now the system is working fine with the two regular hard drives so I’m thinking I’ll simply buy another motherboard for my main system and use this one as a backup or a HTPC since it seems to work just fine with regular hard drives. If anybody out there has any ideas let me know.
