Hello,
Just got the parts today, put it all together. It fires up fine. I obviously wanted to configure my raid array before I begin to load windows. The first time I select RAID from the SATA options everything works fine. I reboot, select the drives I want to be in the array, put in my windows disk and to my dismay I forgot my vista cd was an upgrade so I'll have to load xp first. I reboot with an xp disk in there and it hangs in the Intel raid screen. It's trying to find the drives in my array. It stays there and won't move any further. I let it sit for about 10 min to see if I'd get an error, but nothing. I've since cleared the CMOS several times and each time I clear them it will start to post fine and detect every drive. The second I re-enable raid from the BIOS it gets stuck again. I've tried swapping ports, cables, drives...nothing helps. One thing of note...it used to get stuck after finding the second drive in the array. Recently it changed to finding 3 drives and getting stuck on the 4th.
I'm at a loss. Any ideas?
