Gigabyte ga-965p-ds3 matrix raid setup problem
Shwick
Ad Blocker - Banned
I have 2 x 250gb seagate sata drives plugged into the purple raid ports on my gigabyte ga-965p-ds3 motherboard. Both hard drives were tested
on another system and are working properly, the jumpers are removed and they are running at 3.0GB/s. The motherboard is rev 3.3 with
the latest bios, f12.
When I restart my computer I press ctrl+G to enter the raid utility and I want to create two raid 0 arrays, an 80GB and a 420GB. After I create
the 80GB array I can't create another one- I get the message "No Enough Disk For RAID". But clearly only 40GB per drive has been allocated.
Even when I select a drive and press enter the info box tells me the raid config is using 40GB.
Info Box:
Model: ST3250410AS
Serial: ***********
Firmware: 3.AAA
Capacity: 250GB
Channel: SATA Port 0
Transfer: UDMA Mode 6
Addressing: 48-bit LBA
Support 3G: YES
RAID Config: RDD0 40GB
I am able to delete the raid array but it still only lets me make one at a time.
I have my bios set up properly too I think- Onboard SATA/IDE Device is enabled, Onboard SATA/IDE Ctrl Mode is RAID/IDE and SATA AHCI Mode is Disabled.
Isn't this the point of matrix raid? Create multiple arrays, the first one being the fastest?
Has anyone else has this problem or know how to fix it?
Thanks
I'm not a raid guru but to the best of my knowledge your going to need separate drives for each array. Don't believe you can run 2 array's off two drives. Maybe if you set up partitions? IDK, anybody want to pipe in with an answer?
