Ok, I have one of these boards in an Antec P180 and very nice it is too. My problem is that I am unable to use the last PCI-E slot to fit a GTX 285 in because the heatsink is too wide - there's not enough space between the slot and the top of the PSU compartment.
This effectively means that, running 2 GTX 285s as I do, I have to tolerate high temperatures, especially on my primary one, as I have to run both cards in the PCI-E slots nearest the CPU - which means they are right bang next to each other and I can't get custom coolers because there's not enough space for both - yes there would be on the lower one, but not the primary PCI-E slot.
Does anyone else run these cards on this motherboard in that case? Is there any viable solution to this problem? I think the PCI-E bus etc are all down a space in general on this board to accommodatef the custom chipset cooler and the extra 4 USB sockets in the IO bay.
But I need to cool down my precious GTX cards - running at about 85 degrees isn't good.
Any advice?
Any advice?
