sadbuttrue
- Feb 16, 2008
Gigabyte p55 ud5 + i5 750
I've set cpu voltage to normal and dynamic voltage to +0.05. All reporting software (including easytune hw monitor) shows the peak voltage to be Normal + Dynamic (1.26 + 0.05) = 1.31 under single core load.
However, I'm concerned about what easytune is reporting. In the tuner->advance->voltage tab it shows vcore as 1.51250v. This value never changes, regardless of what dynamic voltage setting I apply. When not using dynamic voltage the value matches what I have set in the bios.
I'm hoping this is simply easytune being unable to take the dynamic voltage setting into account. Has anyone come across this before? If all other software shows voltage at the correct levels, should I just ignore the easytune value?
