Gigabyte DS3 and S3
The DS3 has solid state capacitors which last longer than regular capacitors (say 10 years as opposed to 5). The S3 has regular capacitors. Other than that, they are the same board.
yes the ds-has solid caps and cost about $40 more . the extra durability of the DS-3 over the regular s-3 is somewhat debatable--because the DS 3 --nor any other mb i know of uses all solid caps . so there are still a few regular caps on the MB . the solid caps are used in the "critical" areas.this arrangement is SUPPOSED to give an extra 20%-40% more life . so if it's worth it extra $$$ is still a open question . i bought the regular s-3 myself . as many mb's as i go through overclocking a couple years is about all i ever use one for anyway --i usually get 2 1/2 to 3 years mostly between mb's. since it's not a huge price diffrence between the $120 s-3 and the $140-$160 ds-3 it's really sort of a toss-up. :cool:
The price of the DS3 is starting to drop. They can be had for right around $130 now. Still about $20 more expensive than the S3.
yea--if they had had the ds-3 for the $130ish price i might have got one instead of the s-3. i might just pick up a ds-3 at that price myself !
:cool:
Small Correction, the S3 definitely has "Some" solid state capacitors but not all (or as many as the DS3) . I assume the solid state ones are to replace the higher risk electrolytic ones more likely to swell long term around the CPU socket.
In my opinion the DS3 is not worth the extra money as the S3 will likely last beyond many other brands anyway with no solid caps anyway. Add to this it is basically idential in every way that $20-30 ish reason for getting the DS3 is looking rather weak.
