I'm looking to pick up a motherboard for an Intel based server build. I've worked with the G1-B150M-D3H GSM before and was going to pick one of those up. However, in searching, I also see a GA-B150M-D3H which is about $30+ cheaper.
Comapring the specs, it appears they are nearly the same motherboard. So what's the deal with the GSM designated boards? Is the only difference being that they will keep them in supply for at least 2 years and they have advanced RMA?
Thanks!
Thanks!
