Gigabyte chipset heatsink
catkicker
Little help please I have a gigabyte K8NS Pro MB I'm trying to take chipset heatsink and fan off, MB is still in the case. There are to spring load thingies with white plastic caps holding the base to the MB. tried twisting no luck. it has the heatsink fan on the chipset.
Look at the underside, it probably has a middle part with a tab sticking out to either side locking it to the hole. Pinch 'em together & it should push through from that side, then you should be able to take the thing off. I have some jewelry pliers I use for doing stuff like that.
