Does this case have good cooling? and does it have a good amount of space?
Here's pic: http://www.newegg.com/Product/Product.aspx?Item=N82E16811233003
It doesn't have good airflow (http://www.antec.com/pdf/customPC_p180test.pdf), is built from thin and flimsy 1mm aluminum, and looks ugly. For $30 more you can get one of these beauties: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=104&products_id=4260
It looks way better, has much better craftsmanship, is made from thick 2mm aluminum, and has much better airflow.
do you HONESTLY think antec is going to host an UNBIASED review of competitor cases? also, the 3daurora's temperature range is 2 degrees smaller than the p180's so its brighter. tis marketing propaganda
i DO agree the v1000 is 1000x betterim getting a v2000 eventually
The article isn't by Antec, it's by some magazine. I screwed up the link, here it is: http://www.antec.com/customPC_TemperatureTest.html Anyway I've read a lot of complaints on forums regarding the aurora airflow.
they also used the vented side panel version... which is just pointless because its a negative pressure case... if it were a solid panel it would have likely been much better
not to mention theyre system is pretty terrible 0_0 101 degree load for the graphics card? can you say artifacts?![]()
They had the side panel off with clingfilm over it for the ir camera. They're testing it in a 35c chamber, so that's why the temps are so high.
