vanilla_guerilla
- Oct 3, 2005
the only mod i have is that thing i nailed on to the top. slightly disappointed, went from a blue wavemaster to this. quieter, lighter, taller, side panels are easier to remove then the wave. but i think the sides and top are spray painted sheet steel. fans turn too slow, not getting enough from the intake in front. i will swap it out for a thermaltake or antec 2000 rpm, because my vid card's and chiset temps very high. or maybe put a hole and fan in the window. feets (feets) are cheesy and loose. door opens on wrong side for a righty, and no way to switch. everything inside that front door is plastic. nice big window, hides psu and cabling also hides the floor so you could stash a light or something here if you did that kind of stuff. my cpu temps are slightly lower. drive cage non removable. better cases around (wavemaster) for the yard and a half, but most of the nice new cases, stacker 830, temjin tj07, lian li v1xxx, 2xxx are all $250 and up.
