Gigabyte A75-UD4H
Borgschulze
So I built this budget computer... in hopes of doing some overclocking.
I've hit a brick wall, VERY quickly.
BCLK won't go anywhere worth spending the time to overclock it.
110mhz and my SSD is invisible.
133 + 134mhz also invisible.
I thought there was a divider at 133?
I've not been able to find what safe voltages are for the NB either... I tried upping it to the second setting, which is around 0.05 I think. But still.. no SATA for my SSD.
The other thing I should mention... my Seagate 500gb Laptop HDD that I'm using for storage.. shows up in BIOS.
Any help making my SATA ports work would be awesome... and I won't take.. switch to another SATA port as an answer, I believe all components should work when overclocking.. otherwise I'm sure the long term affect will be a non-functioning SATA controller.
I've updated to the F6 BIOS, which didn't help...
I also like the ability to "fake" overclock on this system... I can up the multiplier as high as I want, and it functions perfectly fine, with zero performance gain.
