GigaByte 965-DS3 Strange Problem... Need Help... SOS
jojobar
I have a machine with Gigabyte 965-DS3 that was working just fine for one year or so. Suddently Windows VISTA started giving problems and would not work.
On BIOS setup, it does not show any drives (However, VISTA boots just fine but it does not do anything).
On the BIOS I have set the SATA in AHCI mode (no RAID). On standard CMOS setup screen all IDE channnels show up as None.
I have one Raptor WD-74 and another seagate SATA drive.
If I change the SATA mode to IDE, it adds Channel 7 and Channel 8 as the new drive (on BIOS Standard CMOS settings screen). However the Channel 0 to 4 are showing None and vista does not work.
I can only do a windows 98 boot from a CD. Cannot reinstall OS as BIOS does not see the drives!
Any sugestions (short of buying a new mobo) will be very much appreciated.
It seems like vista is recognizing the drive but BIOS cannot!
Thanks
jojobar
OK a couple of things to check.
First, check with WD and Seagate if there might be a firmware update for the DRIVES. Contact support, they'll send you a firmware and you will have to flash the drives. It will wipe the drives when you do so, so make backups.
Second, you have to load the drivers for the AHCI mode, they are on the CD. The AHCI Mode only runs off the two Gigabyte ports (the purple ones). If you don't do that, then you will have problems.
Revert back to IDE Mode (not AHCI) in the BIOS.
Swap the drives over to the Intel based SATA ports (the yellow ones).
Boot into Vista and load the drivers.
Shut down, swap the drives to the Gigabye ports and change the BIOS.
See pages 65-77 of the manual for more complete instructions. Hope this helps.
I don't know if this helps or not, but the BIOS on my GA-P35-DS3P does not detect the drives in the "Standard CMOS Features" section since I've changed it to AHCI. The Intel AHCI BIOS will detect them, however. This seems to be normal, albeit misleading behavior.
Thanks Drexl, that tells me that my BIOS is just fine... I will follow the suggestions made by qdemn7 tomorrow and see where it takes me. I will report the result here.
Thanks
Jojobar
Forgot to add one thing. The Intel SATA/ RAID drivers for the yellow SATA ports are here.
Okay I did change the drives to IDE and tried to boot. It recognized the drive but still VISTA would not work. As Microsoft technicians had given up on it already, I decided to reformat my drive and this time installed a more stable OS (XP Pro).
Everything seems to be fine and thanks for all the help.
One last question, is there a significant speed advantage running the drives in the AHCI mode? I think my machine screw up had something to do with running drives in ACPI mode.
- Jojobar
Significant? No..... Read:
http://en.wikipedia.org/wiki/AHCI and http://en.wikipedia.org/wiki/Native_Command_Queuing
Native Command Queuing (NCQ) is a technology designed to increase performance of SATA hard disks under certain situations by allowing the individual hard disk to internally optimize the order in which received read and write commands are executed. This can reduce the amount of unnecessary going back-and-forth on the drive's heads, resulting in increased performance (and slightly decreased wear of the drive) for workloads where multiple simultaneous read/write requests are outstanding, most often occurring in server-type applications. However, the current technology actually slows down HD access in certain applications, like games and sequential reads & writes, because of the added latency induced by NCQ logic
I don't understand what the problem could be; I had no trouble using AHCI mode and installing Vista. Did you format the drive/partition while the system was in AHCI mode before installing? I don't know if it works on a partition that was formatted when the system was in PATA mode.
I think when I uinstalled it first time I formatted the drive in then AHCI mode. Maybe I have some hardware/driver problem.
