Gigabyte 8knxp problem
Robbins1940
Installed this board this afternoon and it powers up but doesn't do anything. I get no beep, memory works fine, cpu works but the motherboard doesn't want to post.
Changed back to my old motherboard and everything works.
What could be the problem?
David
What's your exact configuration? Just wondering since I run the same board and thought I might be able to help. And have you tried starting it outside the case?
Pentium 4 2.4ghz 800 fsb cpu
Hercules 9100 agp graphics
256mb pc2100
40gb maxtor hard drive
dvd-ram drive
cd-rw drive
300w power supply
Do you think it could be the psu at fault?
Thanks,
David
With that small of a PSU, I think it could very well be causing you some problems.... Have you tried taking it down to just CPU, RAM and VC and seeing if it'll do anything that way?
Sorry to hear that. Have you tried it with different RAM? Was wondering cause you said you think you got bad memory.
Its both.
Shouldn't buy stuff off Ebay.
The memory was brought locally I can return it if I can find the receipt.
David
I think it could be memory or psu, I have the same mobo with 3500 512 kb dual channel equals 1 gb of ram with 560 watts of power so Im wondering if its your psu or ram.... maybe both?
ebay is bad to buy comp stuff...
