i got this from newegg but at giga's website they have a version 2 also... which one did i buy? or is the v.2 obvious somewhere...
also when i install bios updates, it completes the process and then the screen is just blank.
is it safe to just press the restart button or is it burning something into the flash/ram?
i was told to do the updates version by version up to the latest.. is that person correct that they are not comulatative (spl?)
finally, is there a update to the temp sensor problem? or is there a way to deactivate it using resistors or something. having it say 65 deg cel when you can touch the cpu hs (at ~80deg fer) is scarry... also the fans run at full power... if i reroute all the fans (including psu, silverstone 460) to a controller with temp gauges.. will the fan sensors freak out anywhere?
