Gigabyte 7NNXP Still won't Boot
Psycho
I have tried everything and i'm about to fucking explode. Everything is checked and rechecked. It's installed in a Thermaltake case with a Antec True Power 550W Power supply. Does anyone have any suggestions on what i should do next?
Psycho,
Lets go over the basic common issues:
Did you plug in the 12v 4pin power as well as the atx?
The cpu socket is rotated 90 degrees, did you recognize that and is your cpu sitting properly?
What ram?, how many sticks? what slots?
did you try with just one stick, and have you tried a diff brand of ram.
What psu comes in that case, and what does the psu label say the wattage output for the 12v, 5v, and 3v rails are?
Laterz,
dafanman:cool:
Try pulling out the battery and the jumper next to it to reset the bios along with what the above post said.
Welp... I'm getting just one Long Beep code and there's nothing about it in my manual. Any ideas?
Remove and re-insert your memory and video card. Be firm (without breaking it!) Make sure your Radeon (if it's the system in your sig?) has the power connector attached.
Just tried a Radeon 9600 Pro and 2 sticks of PC2700.. Thinkin it may be the power supply. Going to switch back in my Antec 550 True Power one now
Beep code gone after i switched back to the antec 550W true power but still no processor fan
Psycho,
What brand is the ram?
And did you check that the hs is sitting properly?
dafanman
And what about the 12v 4 pin, is it connected?
Kingston HyperX ram
Yeah the HS is on perfectly
and the 4 pin is plugged in.
I just connected all the fans and the beep code came back. This motherfuckin thing is driving me crazy.
If i killed the processor... What would the computer do? Would it give me a beep code?
It honestly can't be the power supply or the Ram.. Tried PC2700 in it before and a Radeon 9600 Pro and it still gave me a beep.
Wouldnt hurt at this point to pull the processor, clean it up and inspect it.
You got any buddy's that will let you test their processor in your board?
That's the problem.. Everyone runs Intel's when it comes to friends. :)
Maybe i could pick up a cheap duron and try it out
