Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm not sure there's really a need to put an aftermarket cooler on this card, thus far it has been the most silent & lowest temps of any card I have ever owned.
As far as the fitment that's a hard one to say for your nCase, it fits in my IN-WIN 901 with 2-3 mm to spare... I actually had to find a modded low profile 8-pin cable to allow my glass side panel to be installed.
What I can tell you is the card comes out about 26mm from the pci slot where you screw in the graphics card, a non-sleeved/bare wire 8-pin will protrude around 8mm past that.
ebay user new_used_computer_parts has a selection of low profile PCI-E extensions you can buy, he will also custom make them to your specifications as he did with mine.
