finding reviews and performance / spec comparisons on the net for gigabit switches doesn't yield a lot of results. the best i could find is here;
http://www.smallnetbuilder.com/lanwan/lanwan-reviews/30195-8-port-gigabit-switch-roundup
but it's fairly old (2007). it compares the following switches;
-Belkin F5D5141-8
-D-Link DGS-2208
-Linksys SD2008
-Netgear GS108
-Netgear GS608
-Trendnet TEG-S8
the review in a nutshell shows the 'Netgear GS608' as the best performer, its a pitty it stuck in a shitty cheap looking white plastic case. if i came in the standard blue metal casing (like other netgear stuff) with front facing ports, i'd serioulsy consider getting that one.
a couple of forums swears by HP ProCurve (unmanaged & managed) devices though they are a little more difficult to source locally (and a bit more expensive).
i can find most of the switches in the roundup locally.
my local retailers also have the ones below as well;
Asus GX-D1081
D-Link DGS 1008D
TP-Link 8 port
Tenda 8 port
Edimax 8 port
as you can tell by the models listed here, i'm not looking for a managed switch. looking for a unit;
-spend $100 max.
-full 16Gb bandwidth
-jumbo frames support
-some sort of eco / energy switching feature to reduce wattage when idle,
-excellent thru-put performance
-bit of a warrantee would be nice
-not too fussed on wether is uses store and forward or straight thru for transmission. i understand 'store and forward' used to create a performance hit, not sure if this is still an issue any more.
if anyone can find some linkages for a more recent comparison on the net or want to share their experiences with their own equipment, be much appreciated.
cheers.
-Belkin F5D5141-8
-D-Link DGS-2208
-Linksys SD2008
-Netgear GS108
-Netgear GS608
-Trendnet TEG-S8
Asus GX-D1081
D-Link DGS 1008D
TP-Link 8 port
Tenda 8 port
Edimax 8 port
-spend $100 max.
cheers.
