Gigabite-5SMM CPU upgrade SW2 .
I want to upgrade Cyrix M2 x86 366 to AMD K6-2 459mhz CPU.
I do not know how to set up SW2 in the Gigabyte GA-5SMM motherboad.
No detailed info in Gigabyte manual.
The Gigabyte GA-5SMM will do any of the K6-2, K-3, K6-2+, and K6-3+ cpu's with the lastest Bios. You did get the latest Bios and manual from Gigabyte's website Here didn't you??
I've built many a K6-2, K6-3+ system over the years and never heard of a AMD K6-2 459mhz CPU. ;) You shouldn't have any problems doing the swap from the Cyrix to the K6-2. I've done several - just be sure to drop the voltage to the proper level. The motherboard manual will show you how - it's easy to do.
