KrAzYaZnFLiP808
- Apr 12, 2011
Hey guys. Man am I stumped. I thought I had all of this mumbo jumbo crap down, but I guess I do not. Networking and software has been my biggest weakness in my computer hobby. I understand the very basics, and I can set keys for wireless, port forward and so on and so on. But man am I stumped. I need your guys help. I appreciate your guys time. On to my problem.
I use this program called teracopy. It's alot better then windows program. If anything goes wrong with the copying, you can pick up where you left off, instead of doing all over again. It tells me my speeds during tranfer. I have mostly green drives and a Raptor drive. I get speeds of 58-62 Mb/s during transfer between drives in eSata/Sata 3 connection. Seems like its the drives bottleneck. If I transfer between my usb 2.0 drives, USB/USB or Sata/USB, its transfers around 28/32 Mb/s. Okay, thats maxing out the connection, so both esata/usb maxes out the bandwidth.
I had a TP Link router which is 10/100 Mbits. I also have a Synology DS 409 which is 100/1000 Mbits. Transfer between this is around 9.8 Mb/s. This is between my computer, connect to router, to NAS. I know 9.8 Mb/s is maxing out my router connection as it says in the manual. I cant really transfer things at that slow of speed, it would take forever. So upgrade to a Gigabit router makes sense.
I just bought a WD N750 Gigabit router. And boy, I cant set this thing straight. I am not sure where the problem lies. I have been through disabling jumbo frames, TCP Checksum, Flow Control, Speed and Duplex. Almost all combinations of settings and I get speeds faster then my old router, but not where I am expecting. I get speeds of USB 2.0. I get between 28-32 Mb/s. I was told gigabit infrastructure is as fast as esata. So I was expecting atleast 58-62 Mb/s on green drives. I am getting half that speed. I do not know where the problem lies. I have cat 5e cables. Is 28-32 Mb/s reasonable speeds connected on a gigabit network? Or should it be faster, to me it just seems I waisted a buck for speeds not as fast as I was expecting.
Any help would be apprecaited. Thanks.
