dr.stevil
- Sep 26, 2008
So I have a Dell Precision M4600 laptop with an Intel Gigabit NIC (Intel 82579LM) . Also on the network is a newer desktop build w/a gigabit NIC, and both machines are connected to a NetGear Nighthawk R7000 with Cat5e cables.
Lately I've noticed a lot of latency when I need to connect remotely to my desktop with Splashtop from my laptop (and poorer than average streaming performance with Steam in Home Streaming). I used a LAN bandwidth testing utility and saw that it was giving me a max of 11MBps... which is a far cry from what I should be getting.
After a little digging, I found that the laptop is only connecting at 100mbps. The desktop, however, is running at the full 1000mbps. Under the device manager, I tried setting the "Speed and Duplex" to gigabit, (edited) (read below, I am able to enable it)
I know for a fact that these cables will handle it just fine as it worked OK with my old laptop (and I could of swore it worked fine on this machine at one point as well). And I KNOW that this NIC is capable of 1000mbps.
Can anyone point me in the right direction as to why this is happening? Or how to fix it? I had a USB3.0 gigabit nic around that I was going to try testing with but can't seem to find it, unfortunately.
thanks in advance
EDIT: OK, so I found the setting to enable full gigabit (I don't know how I missed it). When I try to force full gigabit, it doesn't even connect to the network. The network icon in the task manager shows a yellow triangle. As I said above though, I know for a fact that this cable worked at gigabit speeds with another computer just fine.
thanks in advance
