chilliblast
- Feb 15, 2014
Hi all
I'm looking for some second opinions on a solution idea I am putting together.
Essentially I have a need to host the following VMs:
14 x Windows VMs 3 of which are running SQL Server
10 x Linux VMs mostly network orientated rather than IO
1 x Physical backup server via local disks and IBM LTO6 tape device
Total IOPs approx 5,000
My first thought was to go with 10GbE this is what I loosely specced out:
5-6 Dell R620's 2 x 8C 2.60GHz Procs, 64GB RAM, 2 x DP 10GbE NICS (Broadcom 5718 BT), 1 x QP Gigabit NIC
VMware vSphere Standard / vCenter Server Standard Appliance
HP StoreVirtual 4335 SAN
3x400GB SSD
6x900GB 10k
4xGbE
2x10GbE
HP 6250 LTO drive
2 x Dell 8132's (10GbE)
However that is a little over budget so I may well be pushed to go with gigabit iSCSI, I am worried around latency, throughput (and requirement for 5k IOPs) and frame drops with only gigabit and I cannot afford the luxury of LACP / port channel in VMware Enterprise (i realise LACP does not shuttle IO across multiple GbE iSCSI paths at the sametime, that is the job of MPIO) I can only afford vSphere Standard with HA / vmotion etc.
My aim is to find a suitable gigabit SAN that can handle the IOPs with active / active dual controllers support and aggregate IOs over multiple iSCSI paths (for example 4 x ports per controller). What do you think? Any recommendation on SANs?
Now the question is of suitable switches, heres my list:
Cisco 4948-10GE (but these are EOL i believe??)
Dell PC 5524
Dell PC 7024 / 7048
Cisco 4500-X
Force10 S25N
Force10 S50N
Etc.....
Any thoughts?
With the preferred 10GbE solution the networking and SAN blows out my budget just slightly but worried gigabit will not have low enough latency and high enough throughput but maybe it would be ok with aggregated links?
Thanks all
3x400GB SSD
6x900GB 10k
4xGbE
2x10GbE
HP 6250 LTO drive
Dell PC 5524
Dell PC 7024 / 7048
Cisco 4500-X
Force10 S25N
Force10 S50N
Etc.....
Any thoughts?
Thanks all
