Call amc and say you didn't remember using it and wanted to check the history on it. Usually being nice while sticking to enough truth to still be valid helps. At worst just be totally honest with them about the situation. With the number they're likely to be able to, it's the willingness that's the concern.it was amc and i do have the number. i was thinking of trying to figure out when it was used but not sure how.
