Gibabyte ep43-ds3l problems?
empower64
For about a couple of weeks now it seems like every couple of days or so, after my computer has been off overnight or something, my boot up from power off always messes up, let me explain. For instance, i have noticed that sometimes it will hang at the bios screen and then i will have to restart it in order for it to load windows. Another problem i have noticed is that i will power it on, everything will power up, and then it will kill itself before the bios loads and enter this continuous cycle. I dont know if this is due to overclocking or just some other malfunction, but its getting very irritating! As for as overclocks, there in the sig but have tested 100% prime 95 stable for hours as well as passed intel burn in test!
Well, even if your overclock does appear to be stable, it could still be causing these issues. Try backing down to stock for a little while and see if that fixes it. At the very least, that will tell you whether or not your overclock has something to do with the problem.
