I built this PC one month ago and everything was stable. My problem first started when Windows Explorer stops responding earlier today. I kept having the following problem since then:
0) I start the PC
1) PC beeps
2) CPU is correctly detected. The POST screen displays my CPU and its characteristics.
3) Now, the POST freezes for 15 seconds at the memory detection step. Usually, I should see "Memory runs in Dual Channel" or something like that but the POST screen displays the incomplete word "Memor". This is abnormal.
4) My hard-drives and DVD are detected correctly without any lag.
5) The PCI Devices listing is displayed as expected.
6) A black screen is displayed for 30 seconds. This is abnormal.
7) Windows XP screen appear with the progress bar
8) Another black screen is displayed but it takes 2 minutes to disappear. This is abnormal.
9) The Windows welcome screen finally appears (blue background). It stays like that for 30 seconds . This is abnormal.
10) My wallpaper is displayed for 2 minutes. I have to wait because everything is frozen.
This is abnormal.
11) Windows has finally finished loading.
12) Oddly, Windows XP seems to run well. I can load any program without any lag. This is weird because I would expect Windows to be slow!!!
Those are the steps I have taken so far (without any success):
1) I reset and cleared the CMOS. My E6600 is usually set at 3.2GH (8*400) but now it is running at stock speed.
2) I have 2 sticks of OCZ DDR2-800. I removed each stick one by one and I moved the stick to different slots. I tried every possible combination.
3) Unplug all the unnecessary hardwares (sound card, second HD, DVD) and keep only one ram
4) Unplug the master HD: PC still freeze at the memory detection step.
5) I ran MemTest with one of the stick and no error was found.
6) I ran Othos without any issue.
7) My temps are all great!
I do not think the problem is with the Power supply.
Also, I doubt that the problem is with the master hard drive.
The memory could be culprit but how come MemTest is successful?
The CPU should be fine since I doubt that I would be able to run Windows with a deffective CPU.
My theory is that there is some kind of hardware failure with the motherboard.
Note that I did not change any BIOS settings nor added hardware before the problem first occurred.
Any suggestion?
BTW, All my drives (2 HD + DVD) are SATA.
My specs are listed in my sig.
0) I start the PC
1) PC beeps
This is abnormal.
Any suggestion?
