Giant computer mouse?
Decker87
Hi. I am looking for a big computer mouse. I am so sick of my hand aching because it's too big for a standard sized mouse. I want something light but physically taking a lot of volume, so that my hand can fully wrap around it. Do these even exist?
have u ever consider using a Trackball instead of a regular mouse ?
they are usually large and comfortable :)
Try Contour Perfit. I have large hands and pinched nerves. There are also various"handshake" styles that come in large
Yeah, I love my Kensington. The ball is about the size of a regular billiard ball. There's no grasping like with a traditional mouse, just lay your middle fingers on it and roll around, thumb and pinky are used for left /right click. If I have to use a regular mouse, my hand will start hurting in no time.
http://us.kensington.com/html/2200.html
Warning: These things contain a powerful cat hair magnet. If you have a cat, it is essential that you periodically remove the ball (it's not attached, just lifts right out) and blow out the cat hair for optimal performance. ;)
You can try the Logitech G9. This mouse has an adapter for an extra wide hand (comes with mouse) Check out the pictures here http://www.newegg.com/Product/Product.aspx?Item=N82E16826104079 . I actually use this mouse because of my wider hands, works like no other that I have tried so far.
