Ghost Raid 0 Image to single drive
mainomega
Hello,
I made an image of the OS and all the goodies from my Raid0 array. My question is : will i have a problem ghosting this in to the same setup but minus the raid0 array ?
As long as you boot from the Ghost Floppy - shouldn't be a problem.
I'm assuming that you Ghosted the Array in Windows with one of the newer versions of Ghost.
Because the Ghost Boot Floppy wouldn't have the Array Controller Drivers on it.
Just create a Ghost boot floppy and make sure that the drives that you want to ghost the image to/from can be seen by Ghost.
Ghost will recognize USB drives and any drives that you can see directly in your BIOS setup. That means that they can't be on a non-chipset controller.
Shouldn't be a problem.
Luck
