CrazyLefty
- May 9, 2013
Hi all!
This is our first case done for a customer!
He's a big Ghost in the Shell fan, and loves purple, and we're going to incorporate a raised cut-out and some purple lighting to bring this mod to life.
We are starting with a CM Storm Enforcer case.
Here's the case next to another one that we're doing, its on the right.
We took another side panel, and traced out the cut-out
The cut-out will go on the back side of the motherboard side, and will be raised, with purple LEDs illuminating it from behind.
We will also swap out the included fans for purple LED fans, and add some dangling wires inside and around the case, with UV cold cathode tubes lighting the inside of the case.
Here's a shot of the parts that we will use, most stuff picked up at FrozenCPU.com
We couldn't find a 200MM purple fan, so we will be swapping out the red LEDs in the included fan with purple LEDs.
rough-cutting the raised panel Up until this point most of it was done with a jigsaw, but now I'll have to break out the dremel.
